surferdude2215 wrote:if your pulling it from the bottom will you need to remove the crossmember? because it looks to me like you would have too
The FSM states to remove the crossmember before pulling the motor out thru the hood.
I haven't pulled one myself, but I REALLY want to hear from the people who have actually removed a VG30DE motor from under a Z32. I've looked at my car plenty of times and from what I've seen, the VG30DE motor, with the heads on, is wider than the frame rails. So please explain how you removed the motor thru the bottom of the car.
Thanks.
