Engine swap
A home for 1983–1989 300ZX owners!
mo89300zx
Car: I have a 1989 Nissan 300zx
Hey guys this guy wants to sell an engine off his 85 300 and i don't know if it will be compatible with my 89. Please help thanks
Desert Rat
Car: 2014 370Z M6 Base Coupe
2017 Frontier 4.0
2007 Dodge Ram 2500 Cummins Quad Cab 4x4
1977 F150 4x4 Shorty BUILT
2008 Boulevard C90T
Previous owner of a bunch of Nissans
Aside from some differences in ECU tuning the engines should be pretty much identical. Suggest you take the ECU with it.
mo89300zx
Thanks. Ill just must when I take that engine I get he ECU with it. Must appreciated.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
Your 89 had a "W" series VG, slightly higher compression, full float wrist pins etc. Yes you can run the 85, no you won't need the computer if you run your injectors and oxygen sensor and mas. To run the 85 computer you need the 85 injectors, O2 and MAS.
Return to “300ZX (Z31) Forum”
