nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Mon Apr 28, 2014 4:23 pm
When you did the swap, did you get the ECU tuned for the swap? Have you checked the ECU for codes? Have you tested te injectors? They should read 10-14 ohms. No more, no less. Are you sur you have the wiring correctly on the injectors and coil packs? 5 & 6 are very easy to mix up on the coil packs.
The water coming from the back of the engine could be a number of things, heater core hoses, the many hoses that connect to the plenum, the turbo cooling lines, freeze plugs, and as stated headgasket. MOre than likely a hose, head gaskets normally leak in the in the engine. Did you flush the system before installing the engine?
