racingchick19 »
https://forums.nicoclub.com/racingchick19-u157325.html
Sun Jun 20, 2010 9:44 pm
I have an 89 240sx that I race at a local asphalt track. The engine however is getting quite tired. I have a couple options as what to do now.
1) I have a freshly machined KA24E block bored to .02. I have a rebuild kit to put that one together, I just have to order the pistons and rings. Would the engine get hot fast now due to the boring?
2)Swap the KA24E with a KA24DE w/the wiring harness and ECU.
3)Swap with a Z22. Can someone please explain the pros and cons of the Z22 containing 8 spark plugs? Does it hold up to continuous high RPM's? Can you make it fire as a V8, and would that create more power or would it just be the same and more of a hastle than anything?
4)Pull the one I have in there now and through a rebuild kit in it. Only problem with this is I race every Saturday for the next 6 weeks so I almost have to have something ready outside of the car to make for a quick swap to make the next race. I'm not a fantastic mechanic so I have to have enough time to get things done.
Any advice would be great. Thank you.
