ShaunakaRichard »
https://forums.nicoclub.com/shaunakarichard-u43343.html
Sat Aug 02, 2008 7:41 pm
I know for the SR it doesn't really matter what year it came out of as long as it isn't one from an S15. In case you don't know 89-94 are known as S13. 95-98 is the S14, and 99 is an S15. The S15 motor can work but involves more work. Like I believe the speed sensor is in the rear end so you'd need to look up changing those. And the SR didn't appear til 91, the 89 and 90's were CA18det. Both the S13 and S14 require a little rewiring, but nothing bad at all. You can even pay people to do it if you look around online. Besides the re wiring its a drop in replacement. Though I'd recommend upgrading the fuel pump, the stock one can't keep up.
