ENGINE SWAP
maxima97
Car: 1997 nissan maxima
i have a 97 maxima se with a vq30de, i want to do an engine swap would the 2000 maima engine be able to bolt right up?
Presscott707
Car: 1999 Maxima 5spd
are you doing that just to get lower miles because the 2000 to 2001 max has the sam motor with some things different.
maxima97
na dude i heard that the 2000 vq30dehas 255 horse and my 97 only came wit 190
jltibbs
Car: 2015 Nissan Versa SL
1994 Infiniti Q45
2000 Infiniti I30
the only main difference it that the 00-01 is a VQ30DE-K (00Vi). it has the variable timing. your best bet would be to search MEVI and do this swap. lot cheaper and still some of the same gains.
maxhopper
Car: 02 Maxima SE 6spd
maxima97 wrote:na dude i heard that the 2000 vq30dehas 255 horse and my 97 only came wit 190
The VQ30DE-K came rated at 222hp.
jltibbs wrote:the only main difference it that the 00-01 is a VQ30DE-K (00Vi). it has the variable timing.
Variable intake not timing.
Swapping to a 00 variable intake is still less expensive than the MEVI (I believe). And besides that, I don't know of anyone still selling the MEVI stateside.
Here is a thread regarding the intakes and differences in the VQ30s.zerothread?id=213099
Presscott707
hey i thought the 2000 to 2001 maxs cam with 222 hp and the in 2002 it went to 255 with the VQ35?
jltibbs
1994 Infiniti Q45
2000 Infiniti I30
my bad. 00Vi. variable intake.
scott, with the 00Vi he would have to do an ECU swap, right? if so, the MEVI would be less expensive in that case. i dont know. swaps blow.
Presscott707
jltibbs wrote:scott, with the 00Vi he would have to do an ECU swap, right? if so, the MEVI would be less expensive in that case. i dont know. swaps blow.
yeah man it would be cheaper and less work to just keep your motor and build it.
maxhopper
You can swap the ECU, but it is not mandatory.zerothread?id=121423
