AelSic »
https://forums.nicoclub.com/aelsic-u7352.html
Mon Feb 14, 2005 5:55 pm
I think I finally understand you. If you are talking about just swapping out the accessories the only things that come to mind are changing out the water pump if it has not been done lately, checking the cap and rotor on the distributor, spark plug wires, spark plugs, check the condition of the belts, make sure the power steering is not leaking, and a new clutch may be a good idea everything else should be alright if they were operating fine before. Is this my understanding, new motor putting on old parts?
