troll's 240sx »
https://forums.nicoclub.com/troll-s-240sx-u27176.html
Sun Aug 21, 2005 9:16 am
Yes I've looked and there was one close to my situation but not enough explaination. I have an 95 240sx, and I swapped the engine to another one. The new used one is an auto, and it wont start up. I have checked mutiple things. If I crank with WOT then it will start, but idle at 300 to 400 rpm. Giving it throttle will stall it. Fuel pressure is at 43psi when key is turned on, MAF ground is less than 0.02volts, TPS circuit turned out fine, but it is different than my old one, Timing I believe is correct TDC line is 2nd to last indention on pulley, distributor is aligned from dot to line, all ground has good connection, vaccum lines has no cracks or leaks, fuel lines has no leaks, compression is at 170 on all four. Oh and another thing, the engine is turboed. Last engine was running fine until I boosted too much, I figured just swapping it, it will at least start. If my story is too long and you cant answer then just say SORRY so I will know to try something else, and I would have any problem just let me know thanx.
