driftneil wrote:Have the same problem with my kouki. And my problem is the dash harness. Your best bet is to use the s13 ecu and harness. The s14 is either obd1/2 or obd2, either or, it doesnt work with the obd1 sensors in the 13. And auto harness's are diff from the manual....Good luck.Also the C.A.S. is on the motor on the 13's and on the trans on the 14's, if this isnt connected, you have no pulse signal for your plugs. Check that.Btw, I am doing the same swap tommorrow...Does everything else work out, like the heater core hoses?
Modified by driftneil at 2:10 AM 6/21/2009
Im also doing a 95 Auto KA24DE to a 89 Shell Manual swap! the 89 is a KA24E (SOHC) and i just found the Heater core hoses dont fit to the 95 DOHC how can i modify them to fit or do i have to buy the 95 heater core hoses? I also swapped and replaced the 89 ECU/Harness over to the 95 ECU/Harness and i also would like to know if there is anything else i would need to swap over b4 i drop it in tomorrow morning?driftneil wrote:Have the same problem with my kouki. And my problem is the dash harness. Your best bet is to use the s13 ecu and harness. The s14 is either obd1/2 or obd2, either or, it doesnt work with the obd1 sensors in the 13. And auto harness's are diff from the manual....Good luck.Also the C.A.S. is on the motor on the 13's and on the trans on the 14's, if this isnt connected, you have no pulse signal for your plugs. Check that.Btw, I am doing the same swap tommorrow...Does everything else work out, like the heater core hoses?
