Engine swap opinions please?
Bachemin3
Car: 2005 nissan sentra se-r spec v
I have a 2005 sentra se-r spec v. I've been thinking of which would be cheaper between just adding mods to my engine or a swap...i would appreciate some opinions?.....Also if the swap would be cheaper what would be my best engine choice for to swap with for maximum performance?..
I'm not a Sentra expert, but I think a mild boost kit would be the best bang for the buck.
Member name "nametakennow" has done one, and his turned out great.
Welcome aboard!
Bachemin3
K appreciate it ill look into it...
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
OneFastStanza has a Spec V that is turbo charged. The kit is bolt on and produces moderate power on low boost.
nametakennow
Car: '06 MINI Cooper S
Even on the arguably weak QR, a low-to-moderate boost kit would be better than a swap both in cost and results.
It also responds very well to NA mods (I/H/E/cams/pulleys/balance shaft removal).
VMPhil
Car: 2007 Volkswagen GTI
unfortunately there is no such thing as a cheap swap (unless you think 4-5k is cheap) your current options are an SR20det swap or a VQ35DE swap. the last one is less common though.
original_maht_jones
Car: 1992 Infiniti G20
Could you tell me whether or not you know of the kit to do such a swap? Or maybe a site/company that sells the complete engine? I guess just any recommendation should suffice to set me ahead in progress, really.
nametakennow
Which swap?
For your G20, try http://soko.com for SR20DETs or VEs that you could drop right into your current chassis. For the VQ you *might* be able to use the same kit that Sentra owners use, a member by the name Trav4011 makes those.
SpecV2C
Car: 03 Nissan Sentra SE-R Spec V
there are a few options you have....SR20(played out), VQ35(overrated), VQ30 or just rebuild your motor to hold good boost....if you go to myspecv.com there are a few people on there with swaps.
