g20gearhead wrote:zacmil wrote:Why not just use a FWD sr20det?
bc the g20 is too light in the front end and i would get alot of wheel spin that i dont want
You're going to have to weld in a trans an driveshaft tunnel down the middle of the car and do a whole bunch of rear suspension custom fab work. You know, right?
It sounds like you don't, so just FYI, you can't just "plug in" a rear drive motor into a front drive car.
You're going to need a welding machine ($600 for a good one), learn how to weld (probably 2 months to get good enough), someone to learn off of, get a custom driveshaft made ($1000? easy...), an entire rear subframe from a RWD car with similar wheel spacing and a compatible suspension setup, a lift to measure the subframe compared to the car so you can mount it right, weld in supports for the subframe, attach it to the car, get an engine crane, measure the engine mounts to the engine bay, make custom engine mounts, blah blah blah.
Prove me wrong all you want, but it's probably not going to happen.
