Engine swap/no start??
driftneil
Car: A pile of cars.
Hello all, I recently swapped a newer motor(ka24de) in my car. In the process, I did a 5 speed swap. I Changed the whole front engine harness, so the clutch pedal was needed to start the car. This also made it possible to use the 5 speed trans harness with no cutting of the harness. I dont have the drive shaft installed, or anything past the header i.e. rear o2 and piping. The only thing I can think that would make it not start would be the interior harness not being 5 speed. Because there is a big plug, that went into the auto trans control device. That was under the driver dash, and not used any more. Any input would be great....Thanks guysCar is a 97 240, se....Also noticed today the fuel pump is not coming on, but the car turns over.
Modified by driftneil at 10:41 AM 5/20/2009
Modified by driftneil at 10:43 AM 5/20/2009
driftneil
Does the 97 have a different wiring for the fuel pump relay? It's a 96 harness up till the body harness.....
driftneil
Does anyone know if the 96 front engine harness is compatable with the 97 body harness? I get power to the fuel pump fuse, but no noise of the pump turning on.
