evildky »
https://forums.nicoclub.com/evildky-u13100.html
Thu Mar 19, 2009 1:04 pm
yup, the R200 long snout found in 280Z's S130's Z31's S12's etc si pretty much bulletproof, you'll need the "mustache bar" form a 75-78 280Z manu trans car that came wit the R200 to bolt into the 240z, ideally you want the diff form an 87.5-89 300zx turbo, these are the factory clutch type limited slip units, not cheap use dones bring $6-800, if budget si no issue which isn't a huge issue if you are runnign an rb, just use the housings gears and mustache bar form a 280Z then buy a kaaz, quaiffe carbotech or whatever brand LSD you like
