Engine Swap. Ga or SR harness? Cut Where?
silversentra1999
Car: Nissan Sentra 1999 GXE Limited Edition
Im trying to visualize what i have to do to hook a sr20 in my ga16 powered automatic sentra. both are odb2 so i know it should work . ive been told that i need to use a wireing harness from a NX2000 or Ser. but can i use one from a G20 or would it take some splicing. Id rather not splice, id rather it all be just plug and play. Also is there anything aftermarket i can use like an adapter that can go between my new sr-ecu and my Ga- wires? If not I just want to know what to use and where i shouldnt cut.
silversentra1999
ok so i do also know i can use a G20 harness. i guess im just wondering how do i know where to stop and cut the wires or do i have to cut them at all. or is it all just going to the ECU or Super multiple Junction?
nametakennow
Car: '06 MINI Cooper S
SR harness will simply take the place of your GA harness. The same goes for the ECUs. No reason to splice anything together.
Chris859
On a further note - the g20, and nx2000 harnesses will NOT work directly... g20/nx is a different chassis (p10/p11 vs n14 vs b13/b14)the dash plugs are different(among other small harness differenes). If you get a b14 se-r main engine wiring harness it will plug right into all of the stock dash plugs with no cutting.
Also - you do know that the sr20 won't bolt up to any of the ga16 stuff right? You need new mounts, axles, and a new transmission just to get started.
