Engine swap for my convertible
quantummechanic
Car: 95 convert
This winter I will be doing a swap on my very low mile convertible - in the search for a little more power.
I am not looking to tear off tires or impress my neighbours - it just needs a bit more...
I have a donor wrecked TT but would want to update/improve everything before dropping into its new home.
However...
I'm really liking the idea of more NA power. I have done many, many show winning swaps that look completely factory and now I'm very much leaning towards the VQ37VHR w/6speed out of a newer 370. I can get one relatively cheap. The mechanics and wiring do not scare me at all.
I truly believe it would be cheaper, just as much work, more fuel efficient and of course newer/lighter/pretty cool.
A V8 was looked at (VK, VH, LS*) but too loud and obnoxious for my pretty little conv. :)
Top Priority is it has to look and function as though it was from the factory.
Has it been done? And why shouldn't I attempt it?
300ZXttZMAN
I don't think it has been done and the reason is probably because of the Dollar to HP ratio. Plus the VQ35DE swap is very complex in the S chassis so one can only imagine how complex the VQ37HR would be.
Plus the engine, trans, wiring harness, and ECU is only the beginning... Just change your mind and go a more conventional route hah. :bigthumb:
What kind of budget are you going to be working with?
quantummechanic
Car: 95 convert
Already did change my mind...put a deposit down on a slightly done up LS2.
Budget was around 7-10k
itsa300zx
Car: 1990 300zx NA W/TT swap
2011 Nissan Rogue S
2008 Highlander SR5
Have you seen this kit for your swap?
http://lojinnovations.com/z32%20kit.htm
quantummechanic
Car: 95 convert
itsa300zx wrote:Have you seen this kit for your swap?
Yessir, I've been watching since spring. Now that they have a header and wiring, it just makes more sense to go that route.
Thanks tho :)
