RetroDriverZ wrote:I did that already when I had the timing belt done and still did it. I just cant put up with it jerking everytime its cold out. I had some hope about the SR20DE engine, although I need to know if it matters if the engine works with FWD or RWD, or is it the tranny that matters? I wish the pulsar wasnt FWD so I can just get on with a CA18DET engine.
You need to find a FWD SR20DET engine out of either a early-mid 90's Nissan Bluebird SSS or a Nissan Pulsar GTi-R. Just get the engine, harness and ECU.
After you have procurred those, get a FWD tansmission from any of the FWD stateside SRs.
There was a guy I met about 6 years ago down in KC that had a FWD SRd second gen Pulsar. Stock internals, boost controller full custom turbo back exhaust, small FMIC it ran mid 12's in the quarter.
It's not cheap, but it's doable.
