Chris.Peterson wrote:...two variations of the VQ35de. One to support FWD and one to support RWD. Obviously from what i can see, the oil pan is placed differently on my pathfinder than on my spare engine. However, it is still set up as a RWD configuration, but because it is a 4x4, it also runs the FWD configuration...
...can i switch oil pans to make the vq35de with the RWD configuration work in my pathfinder ? Are the blocks the same ? Can the oil pan and oil pickup be relocated ? Im not incredibly car savvy so im just looking for a bolt up method or a part i can buy online to convert the two.
Thanks for any help.
I referred to these links just to see what the spec differences are on the engines. Seems like they are pretty close in power and torque. Plus they both have variable timing.
http://www.edmunds.com/nissan/pathfinde ... res-specs/
http://www.edmunds.com/infiniti/g35/200 ... res-specs/
that being said, I believe the blocks are the same being RWD. The thing that allows for the 4x4 utility of your Pathy is the transfer case, engine should be the same as a RWD Pathy. Never seen the g35 so I don't know where the dipstick is located. If i recall correctly, the Pathy one goes into the upper oil pan, so it should be easily movable.
I do not know if, and what effect the slightly different engine parameters will have to your ECU, but I have heard of the FWD VQ35 people swapping engines between maximas, rogues, altimas with no reported issues.
However, just confirm the starter locations, upper oil pan and that the transmission bellhousing patterns are the same and all should be well. The intake is also different and I personally wouldn't mind trying a new intake...if all electronics bolt up.
How is the G35 fan ran? How about the a/c compressor, power steering and alternator?
Again, this is just me offering my opinion but never having done the actual swap. Maybe someone else will chime in.
