Engine Swap/Conversion.
1980-1986 Datsun 720 forums. All 720-specific topics and discussion can be found here.
shaunii94
Car: 1985 Nissan 720 Dual Cab Ute
hey guys. I am really curious on getting more power into my 720.
ive heard that they sr20's can be put in the 720.
if anyone knows how much work is involved please help me out?
and anychance someone coulld write me up a parts list that I will need?
and if anyone is will after I get all the parts anyone brave enough to do it for me and ill will pay you? haha.
thanks guys.
Located in Australia. Brisbane/Gold coast area.
crackbaby69
there are alot of posts about this already.
thought about doin the sr but went with a turbo ka instead. alot less work. good luck
Davezilla
Car: 1990 300ZX
1986 720 4x4
Turbo is definitely the best bang for the buck, I'm currently getting ready to set mine up. And to make it even easier, the KA24E exhaust manifol has the same bolt pattern as the Z24 but the KA has round ports and the Z has rounded square ports so you'll need to match port the manifold, but the rest is easy. Also for the carb, it's easier and more reliable to set up a Holley 350 2 barrel for blow thru as well as much more tech info and parts available. I wanted to use my Weber for blow thru but the lack of info on how to set it up made me decide to use the Holley.
cukali
I put a 240sx KA24DE motor in my truck. You have to do some fabricating but its pretty easy with a welder and a good saw.
The first thing that needs to go is the 3.50:1 axle gears with the 240sx transmission. I am going to swap to 4.11's as soon as I can find an axle for it.
Return to “Datsun 720”
