Engine Swap Complete - Transmission Issues
jamesmost
Car: "95Qmodded, Benz wagon 4matic , 1986 MB 560sec
Engine swap is done car purrs and roars BUT will not go into gearMy trans was rebuilt a few months agoput in the Dragon TC after engine swap and it was the wrong one.After manu back and forth w/ precision industries - counting splines, measuring height, and giving the stamping info on the stock convertor.
They sent the correct one - trans shop installed and still nothing.Pump in trans is working you can feel the application.Trans shop says has to be convertor, is gonna pull it hopefully this week.when my engine went car was not moving so dont think any trans damage.Whatcha Think ???
rsiwicki
Car: 95 Q45T
only way to tell is to install the OEM TC and then see if it works. If it works then you know for a fact that it is the aftermarket TC.
jamesmost
rsiwicki wrote:only way to tell is to install the OEM TC and then see if it works. If it works then you know for a fact that it is the aftermarket TC.
i know $ propasition though ?
jamesmost
here is the dilly yo_ precision industries built me the wromg torque convertor a second time.They are sending me UPS call tags for 3 boxes1- first wrong part 300zx TC2- second wrong part custom built Q45 tc a good 1/2 inch too short(input shaft bottomed out- potential trans damage yes pulling apart my newly rebuilt mad sick trans-- to check for potential damage)3- my stock convertor so they can not f**k up again.FYI BTY i am pissed
Rex
Car: None
jamesmost wrote:here is the dilly yo_ precision industries built me the wromg torque convertor a second time.They are sending me UPS call tags for 3 boxes1- first wrong part 300zx TC2- second wrong part custom built Q45 tc a good 1/2 inch too short(input shaft bottomed out- potential trans damage yes pulling apart my newly rebuilt mad sick trans-- to check for potential damage)3- my stock convertor so they can not f**k up again.FYI BTY i am pissed
Glad to hear you're getting to the bbottom of it all, but it sucks how things are going. Can only hope for good results when it's all done.
jamesmost
no doubt UPS picked up the 3 convertors this morning will be at precision on thursday, they said they will try to get the proper convertor out the same day and overnight it to me.in the meantime LABOR $$$$$$$$$$$$$$$$$$$$$
INFINITI Q45
Car: NISMO
Sound like a pain, all the money time and not being able to drive your car. I have had many experiences with companys giving the wrong part, put it on dons'nt work or does'nt fit than have return item get another, its enuf to drive any on loony. But when the car is done right and you hit the road with new upgrades and you can feel the improvment thats when its worth it!!
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
One has to wonder what it is they cannot measure?
louiegz
Car: 2003 BMW 330i, 2007 Audi A3 3.2 Quattro
I'm glad to see your almost there with getting to be able to use your Q again. I hope this TC problem gets sorted out.
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
im glad you can deal with this so that if some of us want to buy a dragon TC, we can do it just fine
jamesmost
elwesso wrote:im glad you can deal with this so that if some of us want to buy a dragon TC, we can do it just fine
no doubt the next one will be easy for them and us
Ramshorn
Car: 65Tbird /Motorcycles
james swapping out eng on my 94 Q45t got any words of wisdom do & don'ts helpful hints etcThxs
jamesmost
knock sensors under plenum jobhollow out the pre cats and remove the catsh20 pumpplugsvalve cover gasketsclean egrall beltscheck tensionersmabey do trans rebuild when all apart save some labor.Make sure your mechanic has some idea of what he is doing. if doing it yourself Fly Wes in from Indiana for assistanceif i can think of anything else i will let u knowalso if u search some of my posts u will find alot of exoerienced peoples input
jamesmost
FYI for those interested - they are machineing a new cover for my convertor today, they had to write a new program for the cnc machine, they said they never saw one like mine (although my 2- stock convertors ae identical) blamed it on the Import manufactures changing things up in the middle of production whan they have a problem w/ a supplier.wil have it back on Friday morning
RobertsnewQ
So that must be why the Z32 converter didn't work for you...
jamesmost
RobertsnewQ wrote:So that must be why the Z32 converter didn't work for you...
It wont work for any Q that was just his BS excuse i think his convertor in the cactory that was labeled Q was probably from a pathfindermy trans guy said the concertor he made(2nd wrong one ) matched no vehicle
