Engine Swap Auto to 5 speed 2.5 Engine?
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
Altimaddict
Car: 2002 Altima 2.5
My 2002 Altima with 5 speed needs an engine. I can get one from an Automatic, cheap.
Can I swap flywheels to use the engine from an automatic with my clutch?
I've done this on VWs and audis, flywheel to pressure plate conversion.
sergofast
I have a 5 speed from an 02 for sale. nothing wrong with it and I live in VA. Ill also have the stock flywheel that you can have as well.
The transmission is from a 3.5 though....i dont know if the bell housings are different for a 2.5 and 3.5 engine.
Shaded05
Car: 2005 altima 2.5S
Automatic to manual should be able to bolt up just fine ... In theory I would just suggest call auto part store and ask for an automatic vs manual to see if same part number pulls
Return to “3rd Generation Altima Sedan (2002-2006)”
