engine swap 90 to 95
Dragoon75
What changes do I need to make aside from ecu and transmisson to put a 95 ka in my 240sx?
Thee 240sx Owner
Car: Canadian 89 240 with LSD/stock no ac/ and 4 motor swaps
dash cluster, transmission, ecu, harness, coil pack, and thats about it... unless someone can think of something else.. i'm freaking tired from doing my swap today...
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Your transmission/flywheel/clutch will bolt up just fine, you can keep them.
And the ECU and wiring harness is necessary to make it easy...
And the DOHC S13 power steering lines.
And a custom A/C bracket if you're keeping your SOHC compressor.
And the cluster, or just the tach...
- Brian
Nismo31
so if i was to swap a DOHC motor into my car 90 s13 w/ SOHC, im able to keep my transmission n just switch the motor?
SxMachine
Car: Im on a horse
Yes
Thee 240sx Owner
the only thing you would have to change is the pilot bushing if you're going from auto to manual or vice versa
