hey SanoSuke so have you done the swap?! Has anybody I mean ANYBODY done this could put there input in the like is it just an engine swap or would you have to switch everything over. also SanoSuke isn't you insta strictly_stance and didn't you paint your car now hahaSanoSuKe wrote:You could put a turbo on a 2.5 and still make power. People turbo 4cyl engines all the time. The only concern is transmission, because the CVT sucks. And answering your question, yes it's do-able. I even considered it once but went a different route. After all my research I just came to the realization that it's better to find a totaled 3.5 and get the parts from it as a donor car. If you buy all the parts NEW or from dealership, it'll cost you an arm and a leg.
But manual 3.5s are so hard to come by is there any other 6MTs out there that would fit our 2.5 and take about 5lbs of boost?Mikeyothepro wrote:Swap the Trans for a 6spd from a 3.5 then you'll be good
Wait what do you mean parts from a 3.5? You dont have a 3.5? Then what did you take off of the 3.5 that would help a 2.5???SanoSuKe wrote:You could put a turbo on a 2.5 and still make power. People turbo 4cyl engines all the time. The only concern is transmission, because the CVT sucks. And answering your question, yes it's do-able. I even considered it once but went a different route. After all my research I just came to the realization that it's better to find a totaled 3.5 and get the parts from it as a donor car. If you buy all the parts NEW or from dealership, it'll cost you an arm and a leg.
