engine swap 07 qr25de into 02 qr25de (altima)
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
blade1245
Car: 2002 nissan altima 2.5
anyone know if my 02 transmission will work with the 07 engine. The flywheel and trq.converter are alittle different. do i need to swap my flywheel and trq converter to the new engine? HELP!!!
low91240sx
Car: 1991 Nissan 240SX LE/2005 Nissan Altima
Well I'm no expert on the engine like alot of the fellas that are on here are. I'm still new to the engine myself but if they are different then I would say yes you need to get different ones
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Does the bolt pattern for the O2 transmission match that of the 07 block? I would think it would be a simple bolt on even if they appeared a little different. I'm going off of assumption, but you'd think they would share the same tolerances if they shared the same bolt pattern.
low91240sx
Nice sig darius like the pic
Darius
haha thanks man! I was quite the little photographer that day. That was the first time all summer that I've gotten the car out AND brought a camera to take pictures of it.
pm_page6776
Car: 2009 A/C 2.5S
I honestly don't know if the bolt patterns are the same but the 02 altima has a 4 speed automatic transmission and the 07 altima has a CVT transmission. If I had to take a guess I would say no it would not fit. If the bolt patterns are indeed the same, yes, you would need to swap the flywheel and torque converter.
Darius
Oh ya forgot they got the CVT in 07. How about you try it and let us know how it goes!! You'll be the first to do it and if it doesn't work, just slap a known good 3rd gen 4-speed on there and say you tried.
Who knows if it will even work with the A/T ECU on the 3rd gen because there are no longer shift points with the CVT. This could turn out to be a cool project if you have the resources and another daily driver.
showtimesaltima
Car: 2003 altima se 3.5 auto
manual motor has no cvt only the auto-matics. yo you can call nissan service they'll let you know . you know something i was thinking of doing the same with my 03 cause the 07 cvt 3.5 is a beast. but im going to do my 4spd swap for the 6spd SER manual. i also plan to rebuild the engine.
Darius
Why are you going to rebuild the engine? Is it shot or are you turboing it or something?
I want to see someone with a 500 hp QR25DET. There are 500 hp 1.6L hondas out there, why have very few people gone the turbo route with this motor?
jamesrw
Car: 2002 Nissan Altima (2.5 5-speed) / 1994 Infiniti J30 (3.0)
I'm am really looking at doing this swap, so I've got to bring this thread back.
...Looking at replacing my 2002 QR25DE with a 2007/2009.
My '02 is a 5-speed but the motors I'm looking at are ATs.. surely I'm keeping my transmission if possible.
What kind of work am I looking at here?
What else needs to be replaced?
Should I say forget it and just get a new ride, or look at a different swap? I'm not trying to build a racecar or anything.
someone out there must have done this one already..
el_blacky06
Car: 2007 Nissan Altima Sedan 2.5s 6MT
interesting idea. i have the qr25de but its a 6 speed manual transmission so right off the back im going to assume it will not fit the transmission from the older models.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
jamesrw wrote:I'm am really looking at doing this swap, so I've got to bring this thread back.
Ok, so maybe I'm missing something here, but if you replace your 2002 QR with a 2007 QR, won't the end result be the same thing in terms of performance, etc.?
The '07 engine has basically the same output as the '02, no?
Return to “3rd Generation Altima Sedan (2002-2006)”
