engine surging
ray666
Car: '92 240 sr powered tuned with a neo
So i've posted over the past couple of weeks about problems i've been having well its not a vacuum leak like i originally thought. the car will idle fine when i first start it up but once i tap the gas. it goes crazy. its like its trying to scan to put itself back to smooth idle. my car has never idled at 700-800 since the swap was done. iacv?
duffman1278
Car: 89 240sx Hatch, the wildcats!
Pressurize your turbo's intake to about 10psi and open up the throttle body, see if you can hear a leak from the piping couplers or IACV. Pressurize it with a compressor too, it's very difficult to hear it with the engine running.
ray666
i will give it a shot.
240SXmotoring
Car: 97/95/90 240sx
also make sure the IACV is not clogged or gunked up.
any CEL?
Justin35ll
Car: s13 coupe sr20det
mine did this on initial start up of my sr. went away after a couple days.Clean the IACV with brake cleen though
ray666
sweet whats the best way to get it out? i'm not familiar with what CEL is?
240SXmotoring
Car: 97/95/90 240sx
CEL= Check Engine Light
ray666
oh duh...no the cel is not on. i ran codes too and nothing popped up.
ray666
i'm gonna clean out the iacv today but i'm not gonna take it out but instead take the screw out and use brake cleaner any advice?
