daroutt »
https://forums.nicoclub.com/daroutt-u143954.html
Sat May 08, 2010 11:34 pm
I have a 2001 QX4. Recently the engine has started surging and running rough, even backfiring on occassion. I have replaced the plugs (vehicle has 104K miles), cleaned the MAF sensor, installed 2 new rear O2's and a new cam shaft sensor. (The last two were done before the surging and backfiring started). Also took it to my local Nissan dealer to see if they could help. All they wanted to do was flash the ECM because they said there was an upgrade that needed to be loaded into the computer. Can anyone tell me if the fuel filter and/or fuel pressure regulator are the problem or this an injector and injector pump issue? Any feedback would be appreciated and helpful.
