Big Red »
https://forums.nicoclub.com/big-red-u2123.html
Sun Feb 15, 2004 8:53 pm
I had the head shaved and a valve grind done and out everything back together but now when it's sitting at idle it will idle just fine.
But as soon as I touch the gas pedal it seems the engine starts to stall and then it revs up just fine, even if the rpm's are dropping from 3,000 to 2,000 and I touch the gas pedal the engine seems to miss before it responds.
I've run the realtime diagnostics in mode 4 & 5 and checked just about every vacuum hose I can think of but I still can't find the problem.
Help please
p.s. I have also noticed small drops of black crap on the floor from the exhaust, not oily but more like water and black dust mixed up.
Oh.... '90 240SX 193K, Head job done 1K ago along with timing chain and guides, oil changed every 3,000 miles, new plugs, wires, distributer, belts, O2 sensor & battery, Compression test 15K ago, all within 2%
