Sound and vibration very reminicent of that.Almost like the valve overlap was off..I immediately called the dealer but they are booked to dec 10th, shut off the engine to check oil (in case I suddenly sprung a leak and also the VVT is oil pressure actuated).
Assorted Background info.
-Engine started back up and ran like a champ after a 8 min shutoff.-Oil at the full mark-1 quart short oil was yesterday.-Engine has 90,000 miles with good oil change habits up to 80,000 miles, and excellent oil change habits (under 3k w/ syn oil and hi end filters) since then (When I bought car engine had 80k miles)-cam guides, cam guide tensioners, oil pump chain/tensioners replaced at T3 10,000 miles ago-newer (last 3 years) knock sensors-newer ox sensors-original injectors ( car was in RFG states its entire life)-2 days ago gassed up at a fishy gas station after the track with everybody from the meet, everyone was low, so we picked the first gas station. pumps very very old as shown by their slow pumping speed so I surmise the tanks were as well.-newer thermostat/radiator no overheating evident-JWT ECU-air filter new-newer fuel filter
This is all contributing info that I can think of, that could possibly be pertinent.I have a couple of things I can speculate about as to causes
Any thoughts as to cause and possible fixes would be greatly appreciated
Fred....
