GarageGuy »
https://forums.nicoclub.com/garageguy-u218314.html
Fri Mar 07, 2014 9:25 pm
hey all. rebuilt my motor to original specs and everything went just fine. only problems im having is when the rpms are coming back down it stumbles almost to the point of stalling. haven't been able to check whether it happens during acceleration. so far it only happens when the rpms are dropping back to idle then it lines itself out and purrs like a kitten at idle.
I took off the egr stuff and most of the vacuum lines. now the only things I have running on vacuum is the fuel pressure regulator and the air swirl control valve. my question is very simple, but probably the most difficult one as well. what did I take off that could be causing the stumbling problems?
some other things I did was take off the ac (didn't work anyway) and I took off the coolant lines that ran to the throttle body.
my plan was to get it retuned but where I live posses a problem for that. All help is appreciated.
