Engine Stumble
joneill1975
My 2002 Maxima 3.5L's engine stumbles when sitting at a stoplight after it has been running a while. The car has 145k miles on it. I have recently replaced two of the ignition coils on it that went bad. The only code I am getting is a pending P1800 which is the VIAS solenoid valve.
My question is does the P1800 cause this sympton I am experiencing or is it most likely another engine coil that is on it's way out and has not thrown a code yet?
Thanks in advance.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
I wouldn't think a VIAS issue would cause idle issues. I'm not all that familiar with the problem, though. Here's a link to more info on the VIAS issue and possible causes: post6311501.html#p6311501
Does it stumble at all under load? Or just at idle? If it's only at idle, I'd say it's probably not an ignition coil. Usually coils will cause a slightly rough idle, but then cause more noticeable issues and loss of power under load and heavier throttle.
joneill1975
It is only at idle, so I am thinking ignition coil especially with the age of the car. There are no misfire codes though.
What problems does the VIAS cause?
