Engine stumble/hesitate at high revs
ReeceZ
Car: Nissan 200SX
Hi guys,
I'm new here, i drive a 94' S13 200SX with the CA motor.
I've been experiencing this problem for a while where the car noticeably stumbles/hesitates at high revs. It happens in 2nd, 3rd and sometimes 4th gear. If i accelarated gradually, it's fine, but happens when i floor it through out. I thought its fueling so I fitted a Walbro 255lph. But that didn't seem to work. The stock turbo has been pushed up to 0.9 bar boost, also have a 2.5" exhaust system, blow off valve, and IC but its mounted just in front of the radiator (which i'm gona change soon). I'm gona put in stand alone management soon. Do you guys think that this will sort it out or is there something else i could do?
Thanks
sjbsuperman1425
Car: 1989 Nissan 240sx
CA18DET
sounds like a boost leak..
Ca_Silvia
Just put your standalone in and go from there. If your a few weeks away frm that, check fuel pressure, clean MAF, Check spark plugs (lean or rich).
What heat range of plug do you have?
ReeceZ
Car: Nissan 200SX
I'm not sure what the heat range is, I have NGK plugs in there, the stock ones which i replaced 3 months ago when this problem started.
ReeceZ
Car: Nissan 200SX
Wouldn't it be happnening all the time if it was a boost leak and not just when i'm flooring it. Could an exhaust leak cause it?
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
ReeceZ wrote:Wouldn't it be happnening all the time if it was a boost leak and not just when i'm flooring it. Could an exhaust leak cause it?
a leak should be omni present. should be checking fuel pressure and if you have a wideband what the A/F is.
I would also check to make sure the 02 sensor is up to spec.
ReeceZ
Car: Nissan 200SX
Don't have a wideband. B4 i forget, I have the stock turbo in there that's been pushed to 0.9bar boost. Could it be that the internal wastegate can't handle it?
boost_boy
ReeceZ wrote:Don't have a wideband. B4 i forget, I have the stock turbo in there that's been pushed to 0.9bar boost. Could it be that the internal wastegate can't handle it?
Turn the boost down and see how it acts.
Dee
ReeceZ
Car: Nissan 200SX
Don't have the money to buy an electronic boost controller. can u turn down boost with a manual boost controller
Ca_Silvia
Wait so stock everything your at .9 bar?
I say check for boost leaks if thats the case.
KEMP
Car: 1990 240sx CA18DET
Yes
