engine still shaking, loss of power!
aziankingz
Car: 1990 240SX SE
Hi all,
So my engine has been having problems..the engine and car would shake after driving it around for a few minutes and sounds like a truck.. I replaced my clutch fan thinking that was the cause and it still shakes and there is a huge loss of power! i sometimes get onto the highway and almost get into accidents bc it seems like theres no power when shifting from 3rd to 4th...i am slower than a geo metro!! i also found out that my alternator belt is loose due to the tensioner bolt which connects to the alternator fell off...so my car has trouble starting without a jump start lately.. any ideas on what the problem could be with the engine shaking and on top of that restricting power? I replaced the plugs/wires, distributor cap/rotor, clutch fan, and fuel filter.
Modified by aziankingz at 1:07 PM 12/1/2007
gtsingh91
Car: 1990 240SX SE
you got into an accident because of that? did the clutch fan fix it for a while or was it still bad when you replaced it?
aziankingz
Car: 1990 240SX SE
no i didnt get into an accident lol...edited my first post...was just exaggerating how slow it is.. the clutch fan didnt fix it..it stopped making the jet plane/super charger noise, but the shaking still resumes...
slidewaysAZN
Car: 1991 Nissan 240sx coupe
i had the same problem. comes to find out i had a dead injector in cylinder one. without touching the car at all carefully pull sparkplug wire of the valve cover one at a time and if you pull it out and the motor hesitates then that cylinder should be good if not either no spark or no fuel. wost case bad compression
simmode1
Car: Red '95 S14
^^^ I agree. I've had to same issue... getting dusted by Geo Metro's... lol!Fuel injectors have gone out on me, like 3-4 times... getting them out can be a B**ch w/o the right tools... good luck, mane!
