hyontiger0826 wrote:I have 59300 miles on my automatic 08 versa.
When the car is parked with engine off for few hours and than when I am trying to turn on the engine it hesitates.
It never failed turn on the engine but it hesitates.
However, when I turn the engine off and turn it on right away the problem is gone. It starts very strongly.
I have new battery 3months ago and I checked the battery and the battery is in perfect condition.
What can be wrong?
Also, I bought the extended warranty do you think it is still under the warranty??
Common problem with the fuel pressure regulator that lets the pressure bleed down when the engine is shut off. Until you get it replaced the easiest thing to do is to turn on the ignition as soon as you get in the car and then buckle up your seat belt and then start the car. This allows the fuel pump a few extra seconds to build the pressure up so the engine catches when the starter is engaged. The fix is to replace the fuel pressure regulator which is part of the fuel pump inside the gas tank. If the car is less than 36 months and has less than 36K miles it is covered by warranty.
Frank 2009 Versa S sedan MT-6 with 20600 miles with 33.2MPG average over the cars life
