latinmaxima wrote:i am actually having the same problem. I am getting ready to replace the cat cause the car had over 300k when the motor blew. the new one has about 97k but it ahs run funny after the first few days or replacing it. the only CEL i kicked was the speed sensor which I messed up when I put the engine and transmission back in. It sits in gear though and will sputter and die. neutral runs great though right?
What's your ID on 502SS? There's quite a few Louisville NICO members. Do you have a 5sp or an automatic? If it's an AT, then I may have a used VSS for you. Did you replace the EGR when you swapped motors?
Apologies to the OP for the thread-jack.
