Engine Start Indicator will not appear
General discussion area for the L32-chassis Altima
TitoValchev
Car: 2010 Nissan Altima 3.5 V6 SR Sedan
Yesterday I installed Stillen's grounding kit. I had the negative terminal detached for about 15 minutes. Once I put everything back into place I noticed that the Engine Start Indicator will not appear on the dash when I open the door. Although the car starts and runs just fine. This happened to me before and after removing the terminal and putting it back into place would fix the problem. This time it did not work. I left it removed for 10,15,30,60 sec or more, but no luck.
Did I burn a fuse or what else could happened?
Return to “4th Generation Altima Sedan (2007-2012)”
