Well when I was trouble shooting why my car wouldnt start (later found out it was the starter and the button just prolonged the failure) I moved a wire that went from the button to a fuse. Now I have to hold the button down, and the key turned while nothing happens, then after holding it and re-trying for a while, it will eventually crank and turn over without any hesitation/problem.
When I hook back up the original setup, nothing happens (regular key turning). What fuse should that wire be going to? Or is there something else wrong?
EDIT: I did some more searching and found this:
So does this mean that I won't need a relay in there if I wire it too the black/yellow feed? Or is this the "high current switch" only?R240NA wrote:It's the simplest thing in the world. All you're doing is using a button to start the car instead of turning the key one more position. Ignition on, wire the button to the black/yellow feed at the key switch to trigger the solenoid. Some kits come with a low current switch and relay, other just use a high current switch. Follow the instructions that came with it, whichever design it is. Do NOT use the orange wire to the ECU, that is a signal wire only.
Then I found this:
This is EXACTLY my problem. I think it's wired with just 2 wires: starter and another one was attached to a fuse (forgot which one though). My starter wouldnt cut off, and since I had to keep it on to move the car, it eventually just cut off while we were moving the car. Is my starter fried?Ritz S14 wrote:I do NOT recommend the high current setup. Because most push button can not handle the amount of current through the button itself it will melt. It can also cause a short to make your starter stay on. Best way to do it is to wire it through a relay.
So Im confused. Where exactly does the relay wire in? I couldn't find any pics, as that would help a LOT.
And if you have a diagram or take the time to explain/show it, please do it in SIMPLE terms (i.e. red wire -> relay -> starter) I dont know **** about electronics/wiring.
EDIT x2: Does this look about right? (the top part is from the FSM and the bottom part is a button by pivot, but I dont necessarily need touse their button, but its a good representation):
