NisanS13turbo »
https://forums.nicoclub.com/nisans13turbo-u22252.html
Thu Jan 27, 2005 6:44 pm
Hey guys, Alrite I got this motor from Rick'ys auto in Florida and i got the motor running for the first time but first it was the ticking noise coming from valve cover. I went inside and tried switching the gears while the engine was running and it just wouldnt go anywhere? What the Fuk is wrong, im so piss because one problem after another and this was a front clip that suppose to start 100%. If this help, when i swapped the clutch, there's was a stage two clutch with loose and missing sprungs and it was pretth bad beat up. Is it that the transmission went out or can it be the drive shaft if it was put in wrong? Please help......
