Engine Start/Accelerating Vibrating Noise
All things Altima Coupe.
lilojoj
Car: 2008 Altima Coupe
Whenever i Start the engine or Accelerate over 2000RPMS i can hear this wierd vibrating noise. Sometimes its there and sometimes its not. All i know is that its coming from the outside. Does anybody else have this problem?
3ugene
Car: 2008 Altima Sedan 3.5SL
its cold where you live... makes perfect sense.
Do you warm up?
lilojoj
i dont know if its the cold. its not even cold compared to where you live. its probably around 60 in the mornings. i usually just go slower than usual until the thermometer is right in the middle. and i think the noise is coming from the exhaust
Hussain
Car: 08 Altima Coupe 3.5se CVT
lol ya i get noise but its from my exhaust. it even gets annoying in the car (sounds like a loud *** bee) but thats the drown (spell check?) from the exhaust in my situation, not sure about yours. but you should always let your car warm before driving. let it warm until it at least hits the line. once it hits the line you can drive it but drive slow till its fully warmed up (when its in the middle).
lilojoj
im pretty sure its not the actual drone of the exhaust. it sounds more like something is vibrating within the exhaust than the actual exhaust itself
frosty606
Car: Nissan altima 2.5s coupe
i thought i had this problem, i realizewd it was my back seatbelt so i tucket it into the seats, idk if that will help.
Do you really need to wait for your thermotere to rise if its like 20 outside and if you dont what happens?
Beak
Car: 08 Coupe VQ
it can be anything. usually something is loose. if you have an intake... that can be loose.. take it to any shop and get it jacked up and see if you can find where its comming from. where do you think its comming from.
VINCENT.929
Car: NISSAN ALTIMA COUPE 2008
I HAD A SIMILAR PROBLEM. TOOK TO DEALER AND THEY HAD TO TIGHTEN UP THE HEAT SHIELD. NOISE GONE.
swizz12
Car: 2008 Nissan Altima Coupe 2.5S
VINCENT.929 wrote:I HAD A SIMILAR PROBLEM. TOOK TO DEALER AND THEY HAD TO TIGHTEN UP THE HEAT SHIELD. NOISE GONE.
same problem & fix for me..
