Engine stand vs Sr20det
1unar3clipse
Car: 93 240sx HB, 01 Dodge Dakota SLT
Alright so I searched on nico and then on google, couldnt find the bolt size to put my sr20 redtop on my engine stand, found the size for a VH45 though
So Although I know its hard to get a prompt answer but it would be nice.
thanks guys!
ser2102
Car: 91 dead. 90 getting did
im gonna guess and say the transmission bolts are 10mm x 1.25? maybe go buy some and cut them to length if need bethats about all i can say.
1unar3clipse
ser2102 wrote:im gonna guess and say the transmission bolts are 10mm x 1.25? maybe go buy some and cut them to length if need bethats about all i can say.
How educated is this guess? What am I going to be bolting from the stand to engine? the trans? Ive never put this type of engine on a stand and I dont want to **** it up.
Come on nico Gurus I know at least one of the mods can either tell me what im bolting into and or the bolt size's are.So what do you say guys?
josephrm
Car: 1995 Nissan 240SX SE
like he said, whatever size bolts you use to bolt the trans to the engine. im not sure what engines you have worked on before, but Nissan engines bolt to the stand using the 4 bolt holes for the transmission....
Hijacker
Car: '92 240sx Convertible
'94 F-150
You bolt into the bolt holes you normally bolt your trans to. Just like every other motor you put on a stand
So you get some bolts that are the same pitch and thread as your transmission bolts but fit your stand better, or you use some spacers and make it work.
RB26Power
Car: 93 240sx fastback
It's 10mmx1.75 i just bought some for mine cuz the ones that i had were too short.
1unar3clipse
RB26Power wrote:It's 10mmx1.75 i just bought some for mine cuz the ones that i had were too short.
Thanks RB26, you have a 93 fastback too?
josephrm wrote:like he said, whatever size bolts you use to bolt the trans to the engine. im not sure what engines you have worked on before, but Nissan engines bolt to the stand using the 4 bolt holes for the transmission....
Worked mostly on gas generator motors and old school V8's which I have never put on a stand, before I had an engine hoist which is alot simpler to hold the motor but I want to build the SR and on a stand I can take my time pulling it apart and yadda yadda.
Thanks everyone for the help.
Jah1mon
Car: s13 coupe
I ended up purchasing m12 bolts for the larger bolt holes located on the block.
MES14AN
Car: "97" 240sx "88" Acura Legend
12mm 1.75 thread pitch 120mm length (120mm depends on the length of the engine stand bolt holes) Is what i used, I Had to make 2 trips to true value already lol!
DrifterProdigy85
Car: 1989 Nissan 240sx (Zenki Onevia)
I managed to use the same bolts that bolt the trans to the engine. Always worked for me. Ive done a RB, SR, and KA this way.
JDS Performance
Bringing this back from the dead to answer the question - you will need
(4) M12 x 1.75 80mm - but keep in mind the length all depends on your engine stand as some have longer holes to go through.
I also use a washer on engine side as well as engine stand side.
I have mine attached @ all 4 corners
This is confirmed on Red & Black tops - not sure on S15 SRs
Now in the last pic - this would be the "best" motor building stand as the stand will not get in the way of you micing out your main journals etc. As long a you got a spare motor mount bracket and somone to weld it for you your good.
voiddweller
Car: 97 Nissan 240SX SE w/S13 SR20DET
04 Honda Accord CL9
Yes, this is an old thread, but relevant.
Need to rebuild my motor this weekend. Did a Google search and this came up for engine stand bolts. Props to the last poster. Very helpful!
