Engine Stand Bolts.
Discuss topics related to the VH41DE, VH45DE, VK45DE, and VK56DE engines.
David Steele
Car: S13 FastBacK
What do you guy do when the bolts for the transmission arent long enough to go throught the fingers on your engine stand?
I found out that my Civic's subframe bolts which are very long thread right into the engine .
http://www.hondaautomotivepart...MOUNT
It's # 18 for the bolts if anyone has ever looked for anything.
Modified by David Steele at 10:43 AM 1/10/2007
SuperHatch
Car: 96 TLC
Well it's funny that you ask...
I couldn't locate any bolts at my local hardware stores to do the job... they're M14x1.5 iirc...
So I made my own... I bought some steel rod stock, and used my metric tap & die set and threaded some rod. I threaded half as M14x1.5 and the other end as M14x1.75 (which the local hardware stores did have). I used them as studs in the block... you can see the pics in my "It's officially Begun" thread...
What a pain in the *** that was. If I didn't NEED to get the motor onto a stand that night I would have ordered bolts from McMaster Carr.
mtcookson
Car: 1991 Nissan 300ZX
1992 Iinfiniti Q45
and much much more
I haven't had that issue with the stand I have. If anything, the stock bolts were a tiny bit too long so I had to use a washer on a couple of them.
David Steele
Car: S13 FastBacK
I just got the engine no Trans. I ordered the transmission bolt from infiniti parts usa and was sent he wrong thing.
mtcookson
1992 Iinfiniti Q45
and much much more
Ahh, ok I get it now. Yeah, if you can get ahold of the stock ones they work really well. They actually fit the holes of the engine stand I have almost perfectly.
defrag010
I had to enlarge the holes in my engine stand to use the stock bolts, but they were no biggie once the holes were big enough.
Ezekial
Car: 2001 Nissan 200SX S15
i went to the bolt shop just up the road and paid $30 AUD for bolts ...
i cant believe this is even being asked??
do you guys not have bolt shops??
David Steele
Car: S13 FastBacK
Ezekial wrote:i went to the bolt shop just up the road and paid $30 AUD for bolts ...
Not everyone: has the same engine stand, got there engine with bolts, know the bolt pattern.
SuperHatch
Car: 96 TLC
Metric bolts are very hard to come by in the states. It would have required ordering at ~$8 a bolt, and then the wait. I needed them then so I made studs myself.
mtcookson
1992 Iinfiniti Q45
and much much more
SuperHatch wrote:Metric bolts are very hard to come by in the states.
Which pisses me off. Whoever though that making a measuring system that required math to get the next size up is stupid... stupid stupid stupid. I have friends that say they like standard better so I'll give them a socket size and tell them to give me the very next step up. They'll sit there for a second and finally give me an answer. Then I'm like, hey... 12 mm is just a tiny bit to small... must be a 13 or maybe a 14... look, no math. I know it right away. Now wasn't that easy.
Ehhh... I think its time for bed.
Return to “VH45DE / VK45DE / VK56DE Forum”
