CCurate wrote:Okay, so My clutch is sticking half way to the floor, but the weird part is the car stalls and makes a engagement noise and vibration in the pedal. I flushed the fluid, but I don't think that is it. Has anyone else had this problem. I have searched but haven't found the exact symptoms. If you've had this problem can you let me know what fixed it. Thanx
Check out what Steve said but you may have that problem as well as a slave cylinder problem
When my clutch pedal came halfway up the dealer replaced the clutch slave cylinder and the clutch fluid under warranty last July at 92k miles
Telcoman
