kclo4 »
https://forums.nicoclub.com/kclo4-u18972.html
Sat Oct 23, 2004 5:19 pm
So here I was bleeding my brakes today when something unexpected happened on the test drive.
The car started fine and ran fine for about a minute. I got on the gas a little to test my brakes and I went to stop hard the car wouldn't. I turned back into my neighborhood only to find that the wheel was hard to turn. Looked down at the tack and it was at 0. I can't figure out why the car would have died. I start it back up and after and it would not rev and after a few moments it died. This was repeated for the rest of the day.
Car starts perfectly fine, then bogs out and dies. It sounds normal till it seems like it runs out of fuel.
There are NO engine codes being thrown which is even more wierd.
If I start the car and give it some gas it will bog out heavily and hesitate. It will rev, bog, rev, bog but it never revs very far before it bogs.
In the troubleshooting I found that the fuel pump runs for its allotted time when the ignition is turned on, but it seems there is no fuel pressure after that initial surge. I haven't got a fuel pressure tester to find out for sure, but I will try that tomorrow.
We took out the fuel pump and gauge and the leads on the fuel pump show about 1Ohm which is in spec. The fuel filter does not appear to be clogged because we unhooked the hose behind the filter to test to see if the pump was working when the ignition was turned on.
This is all completely unexpected as I drove the car last 2 days ago and it performed well.
Any other ways to test the fuel pump or anything else that could be involved?
I did read one interesting thing in the FSM involving the camshaft position sensor. It seems like the fuel pump will not do anything unless the ignition is turned on or the camshaft position sensor is telling the computer that the engine is turning.
The car is a 95 S14 with stock engine.
Beyond this I am stumped. Any help would be great. Tomorrow I will play around some more, but tips on what to try would help out.
Thanks
Paxton
Modified by kclo4 at 4:32 AM 10/24/2004
