Gaude3k »
https://forums.nicoclub.com/gaude3k-u14727.html
Fri Mar 19, 2004 10:15 am
OK, i have seen alot of posts on here with somewhat of the same problem. If my car has run for a little bit, when i go to slow down and push in the clutch the engine stalls, it will start right back up if i start it or pop the clutch. and if it has been runnin for a while and i stop and it doesnt die, the rpms hunt from 100-1000 and it does that for bout 1min, then it dies.
Thanks in advance
