nissanfreak12 »
https://forums.nicoclub.com/nissanfreak12-u177688.html
Sun Mar 06, 2011 9:08 am
Have you checked the codes again? If you cant rev past 2200 or so you are in limp mode. make sure your connectors are clean and nothing else is unplugged.
That is weird you have five prongs, mine has 4 but i have a 92. I also thought it was strange that the fsm shows five as well, hmmm.
You can drive it, I personally wouldn't, possiblity of damaging something is too great. besides it will just irritate ou to no end. Try and call up where you got the MAF and let hem know, maybe early 90's had a diff one, but check everything first.
Coolant temp gauge is the sensor to the right of the temp sensor, it should have one wire coming out and the CTS has two with a crappy plastic connector that easil breaks.
