cjkjday »
https://forums.nicoclub.com/cjkjday-u233310.html
Wed Apr 09, 2014 6:20 pm
I'm struggling with this issue. Been scouring the repair manual & forum and think I've addressed most similar symptoms. I've recently bought a 1996 4x4 HB, KA25E w/5 spd. Been cleaning/tuning it up when it shut down/stalled one day at a stoplight. Ran at high (>2000) RPM....got it home. I had/have a P1320 & P0110 fault code. Replaced plugs, wires (NGK for both) and the distributor. Timing appears good @ 10 BTC... does jump around a couple +/- (normal?). Checked resistance on the 2.2k ohm resistor by the valve cover (good). New fuel & air filters and PCV. Cleaned the EGR, IAC, Throttle body...TPS appears to be working correctly. Sprayed brake cleaner around the vacuum lines...nothing.
Starts up and runs fine when cold... when it warms up, starts to sputter and stall. Will start up right away after... to stall again, but will run if I keep it above ~ 2000. Only other unordinary symptom was the clicking/chatter that was coming at ignition start and shutoff... seems to be coming from the vacuum tank area. Replaced the fuel pump relay...and still have the chatter. Didn't think it was related....did run with that issue. Any suggestions? Thermostat, temp sensors?...don't want to waste time/$$$
