MetallicSlate »
https://forums.nicoclub.com/metallicslate-u175179.html
Tue Apr 19, 2022 4:44 am
Hello all,
My wife's 2012 Nissan Versa SV has been having some trouble starting over the past few weeks. My first inclination was to suspect battery, but the battery is fine. Here are the symptoms.
From a cold start, the engine will start cranking strong, but will begin to sputter until it eventually coughs to life. If she turns the car off and cranks it again, it starts right away with no sputtering or coughing.
We took it to Nissan, but they claimed they could not reproduce the issue and wanted to keep it overnight. Was not an option at the time, but I want to get the opinion of some other owners.
My two main suspicions are either fuel pump or timing. I've changed spark plugs, done an injector cleaning, inspected the air filter, and checked the battery's voltage. All is good there. MAF is clean and oil was recently changed.
Anything else I should consider? Thanks for any and all help.
