bagnasco »
https://forums.nicoclub.com/bagnasco-u63337.html
Wed Oct 29, 2008 1:09 pm
Hey guys. I would really appreciate the help if you can give it.
A little bit about my car first.
My car is a 1990 Nissan 240sx with an SR20DET "Black Top" engine, cold air intake, T25 turbo, and a bunch of other stuff done to it.
My problem is.......everytime i am driving around town, I will push the clutch in and hit the brakes to come to a stop at a red light. Well, when I do this my tachometer drops from a normal 750 rpm to 1000 rpm to 500 rpm and sometimes down to 0 rpm where it stalls....obviously.
I got home, opened my hood up and checked the brake fluid......It is a rustic brown color but it is still full. I havent flushed the brake system yet until I get an answer that maybe it needs new brake fluid.
After checking the brake fluid and seeing that it is still full, I turned the car back on, let it idle at 900 rpm (normal) and then hit the brake. I noticed everytime I hit the brake the rpm gauge would go down to about 700-800 rpm. This makes me think maybe its the alternator when the brake lights come on or maybe I need a new brake cylinder......but then I got to thinking that when I brake with the car still in gear (not in neutral) the tachometer does not go down to 500-0 rpm. This only happens when I disengage my clutch or shift the car into neutral.
Any help would be appreciated.
Modified by bagnasco at 4:49 PM 10/29/2008
Modified by bagnasco at 6:00 PM 10/29/2008
