Engine splash guard 2009 M35X
bluedevil30
Car: 2009 M35X
265,000 miles
My engine splash guard (big plastic cover under the engine) broke off recently and the dealers want $200+ for this part,
Are the any after-market suppliers or cheaper online options? Need guard and hardware for a 2009 M35x.
Ilya
Yep. Tollbooth Willey makes aluminum ones. tbwperformance.com.
CarGuy87
Car: 350z, G37s, M35s
I purchased an aftermarket no-name brand one on ebay for around $80 or $90 cant remember and its trash. The plastic has gotten softer and it has stretched so much in exactly one year that I had to refill the rear holes.
I should have bought an OEM one for a little more.
Ilya
Or just got a solid aluminum one from TBW...instead of throwing money at the problem multiple times...
midnightclub619
Car: 2007 Infiniti M35x
How easy is it to do an oil change with this guard on? From the pics on the website it looks like it has a door for the oil filter. Just curious if I should get one.
Ilya
Yep, it has a door for the filter and a door for the drain bolt. I was the donor car for the M35x and the M56x and on both cars I also had a Fumitomo valve installed so my oil changes are as simple as opening a tap and changing the filter. No fuss.
midnightclub619
Pretty cool. I think I"ll pick one up. MIne is sagging quiet a bit. Time to replace it...
