Engine sounds loud when accelerating
J30boy31
Car: 1994 Infiniti J30
Im wondering why the engine sounds loud when i accelerate or rev past 2k? like the fan is running high or something. Can it be exhaust leak causing the sound? it only happens when im going over 2k rpms otherwise if the car is just running you dont hear it.
gsf1200s
Car: 1993 J30 (no longer with us)
2012 Nissan Versa
2003 Chevy Silverado
2003 Suzuki Bandit
1971 Honda CB750k1
could be the exhaust system is wearing out. In my experience exhaust leaks usually sound like a ticking clock.
fourdrinie
Car: 2019 Q50
if you get your car up on front wheel ramps, you'll be able to hear where it's coming from
J30boy31
Turns out to be the fan clutch. Is it normal for it to roar on cold start or when accelerating?
fourdrinie
Car: 2019 Q50
the FSM says for inspection: check fan coupling for rough operation, oil leakage or bent bimetal....
sounds like yours is toast...
replace
