oh I know but for global changes like k(k is like your injector trim, it tells the ecu how big the injectors are) or base timing,just leave the l/t in the car while your in it,and save the program to file on your pc,when you restart just upload the file.... planning to pick up a consult cable here soon(stanza ecu'd de ftw),just for data logShionS14 wrote:ya i know about the timing and everything i have no idea what you mean by k value. i assuming you are talking about the AF ratio. with that the program is setup only to adjust those values while testing once the you shut off the car or disconnect the consult it goes back to the self learned program.
Modified by ShionS14 at 10:17 PM 7/20/2007
