Bud »
https://forums.nicoclub.com/bud-u6039.html
Sat Apr 26, 2003 4:18 am
Ok, I've been getting this car back into shape and I'm almost satisfied except this reoccuring smoke problem.Before I get into details let me stress that the car runs really strong. After doing the timing, plugs, cap and rotor, and a 300 zx fuel filter, I am very impressed with the acceleration of the motor. It is (supposedly) a '93 ka24de into my '91. The swap looks pretty clean except they removed a bunch of emmisions type stuff (EGR, maybe AIV). The pipe coming off of the exhaust manifold is crimped up tight. I will also be putting in a new O2 sensor when it arrives :sopadope!Ok, so basically on some days, when the car idles for a bit at a light or whatever, when I take off there will be a nice puff (or sometimes cloud) of white smoke. Now when I first saw it I said white smoke=oil. But my levels have remained steady through all of this. Also if there were a bad gasket or whatever, would it smoke all the time? Again it only happens when the car idles for a bit, or when I drive really slow through a parking lot or something where I'm on and off the clutch in 1st gear. My bro suggested a valve seal might do this, weeping a little oil here and there. Also, the idle is steady...it was high (1200) but I adjusted the idle screw and it will drop down to 750 or so after about 3 seconds at a stop. My inital feeling (hope) was that it was fuel. The car was without cat for a bit until I had my high flow welded in...the effect was lessened for a while but it returned with a vengence last night after slowly cruising a parking lot for 5 min or so....ok, that about all I can think of - your suggestions?Edit: just got done testing out my new all seasons in the rain. Drove it hard for a half an hour and no smoke whatsoever.
